Pinpointer Sun Ray do EX SE ??
cop50
Post autor: cop50 »
Witam Cię ProScanie :D
Czy miałeś do czynienia z:
http://www.sunraydetector.com/
opis urządzenia zaczerpnięty z powyższej stronki - SUN RAY X-1 TARGET PROBE
for the Minelab Explorer S, XS, II, SE & Quattro
Accurate "bulls eye" pinpointing on coin size targets up to 3" + deep depending on settings, ground and moisture conditions!
Light weight, waterproof/submersible 1" X 9" probe. Comes with a very flexible heavy duty custom 30" straight cable with strain relief for "tangle free" operation, and mounts nicely along the Explorer's battery compartment or on top of upper shaft.
Very compact, ultra light switch box mounted on bottom of upper shaft makes for easy switching from coil to probe. Makes coil changes super fast as coil cable will no longer be inserted into upper shaft! While the X-1 probe is waterproof the switch box is water resistant and must not be submersed.
X-1 gives operator ALL of the same functions as stock coil including accurate visual and audible target ID in both Smartfind & Digital mode, non-motion pinpoint, etc.
Accurate approximate depth indications from tip of probe to target can be achieved through visual observation of the Explorer's depth gauge (although the scale will be different). Scale is explained in X-1 instructions. Accuracy on coin size targets only.
Quality high performance toggle switch used for peak performance! (Minimum 100,000 mechanical life operation-as described in manufacturer's specs)
Toggle switch shuts off coil as it turns probe on and vise versa. Coil and probe are never on at the same time.
No external buzzers or lights are needed as all targets are heard clearly through your detector headphones!
No extra batteries required as the X-1 utilizes the detectors power source.
Complete installation & operation instructions included.
FULL 12 MONTH WARRANTY!!
No more Empty holes! No more scratched or damaged targets!
Experience a Sun Ray in-line probe on your detector and you'll wonder how you ever got along without it!!
Order Yours Today!!!
Only $179.95 + S&H
(Note: Above price does not include the upper shaft. If you are not sending in your upper shaft for modification add $34.95 for a new upper shaft with pre-mounted probe.)
We now have a good supply of Explorer II, Quattro and the new SE upper shafts in stock! Minelab no longer manufactures the XS upper shaft and our supply is exhausted. If you need an X-1 for your Explorer S or XS you will either have to send us your upper shaft for modification or have your Sun Ray Dealer send it in for you.
NOTE: Your Explorer II or Quattro upper shaft must be sent to Sun Ray for the X-1 Probe installation or a new one may be purchased from your dealer or direct from Sun Ray. Contact your local Sun Ray Dealer or Sun Ray Detector Electronics direct for full details. When ordering X-1 be sure to state which arm you swing with (right or left) for proper probe switch installation.
(WARNING: The Explorer XS & S upper shaft is not recommended for use with the new Explorer II/Quattro control housing and may damage the locking system.) NOTE: We except no responsibility for any damage caused to the Explorer II/Quattro control housing if you choose to use the XS & S upper shaft for your X-1 Probe installation on the new Explorer II/Quattro.)
Sun Ray Detector Electronics has been manufacturing multi-frequency in-line probes since 1997. Our design and production engineer has been designing and building probes for over 11 years which include in-line multi-frequency, stand alone as well as pulse and has designed and built pulse detectors and circuits. The popularity of our in-line probes is well known in the metal detecting industry and satisfied customers tell us our quality is second to none!
Z tego co rozumiem, jest to rodzaj pinpointera. Czy zetknąłeś się z tym urządzeniem? Czy jest sens rozbudowywać Explorera SE o tego typu ustrojstwo?
cop50
Re: Pinpointer Sun Ray do EX SE ??
Sam używam czegoś takiego tyle że z pewną modyfiacją. Zamieszczę później kilka zdjęć to sprawa się wyjaśni.
Troszke można zobaczyć na zdjęciu tutaj: http://www.poszukiwanieskarbow.com/Foru ... c&start=24
cop50
Post autor: cop50 »
Ok, czekam na dalsze informacje.
P.S. Zrobiliście kawał dobrej roboty =D>
Wyślę emailem - będzie szybciej.
cop50
Post autor: cop50 »
Z góry dziękuję
cop50
kris
Post autor: kris »
mozna prosic rowniez o takiego maila ...??
z gory dziekuje :)
Kris
ryhopl
Post autor: ryhopl »
Jestem zinreresowny kupnem takiego sprzętu gdzie mógłbym dostac w Polsce taki sprzęt, do minelaba profesjonala .SUN RAY X-1 TARGET PROBE
