Garrett Propointer AT nowy pinpointer.
lechowiec
Post autor: lechowiec »
Wchodzi na rynek następca kultowego już pinpointera. Wygląda na odpowiedź na TRX od White'sa. Nawet kolory się zgadzają:). Poniżej trochę informacji ale niestety nie w języku ojczystym.
http://www.garrett.com/hobbysite/hbby_p ... _main.aspx
Pro-Pointer AT Unique Features:
Fully waterproof to 10 feet with orange color for added visibility underwater.
Maximum Sensitivity for improved detection of nuggets and other small targets. Choose from three Sensitivity levels.
Fast Retune: Quick button press instantly tunes out environment or narrows detection field for precise pinpointing of larger targets.
Retuning allows user to quickly:
Shrink detection field to precisely pinpoint large targets
Tune out mineralized ground, wet beach sand, etc.
Help gauge target size/distance
Help identify edges of large target
Pinpoint multiple targets versus one large target signal
Lost Pro-Pointer Alarm: After 5 minutes with no button presses, the pinpointer emits periodic warning chirps.
Automatic power off after 5 minutes of warning chirps; saves batteries.
Simple, single-button operation for Power, Retune, Sensitivity adjustment, and Stealth Mode.
Ruler in Inches and Centimeters molded into side of pinpointer to judge target depth.
Lanyard Attachment Loop molded into side of pinpointer.
New power button is easy to operate even with gloves.
Other Pro-Pointer AT Features:
Patented Proportional Audio/Vibration
Patented scraping blade for searching soil
Twice the battery life of other pinpointers with LED lights.
Pinpointing tip and 360° detection area
LED Flashlight for low light uses.
Includes woven belt holster and 9-volt battery.
Large power button
Specyfikacja: http://www.garrett.com/hobbysite/pdfs/1 ... lowres.pdf
Model Name: Garrett Pro-Pointer® AT
Product Number: 1140900
Operating Temperatures: -35°F (-37°C) to 158°F (70°C)
Operating Frequency: 11.5 kHz
Waterproof Rating: 10 foot (3 meter) maximum depth; IP 68
Tuning: Automatic or manual retune
Indicators: Proportional audio/vibration pulse rate
Controls: Power, Retune, Adjust switch
Dimensions: Length: 9" (22.9 cm)
Thickness: 1.5" (3.8 cm) tapered to .875" (2.2 cm)
Weight: 6.5 oz. (0.2 kg.), with battery in
Battery: Single 9V (included)
Battery Life: Carbon: 16 hours
Alkaline: 30 hours
Rechargeable: 8 hours
Warranty: 2 Years, Limited Parts/Labor
Patent Information: US 7,575,065 and patents pending
Instrukcja obsługi: http://www.garrett.com/hobbysite/hbby-m ... nglish.pdf
Re: Garrett Propointer AT nowy pinpointer.
Znalazłem na forum PS zgrabny i wartościowy opis porównujący propionter AT (zwany "marchewą") do poprzednika;
Garrett Pro-pointer VS Pro-pointer AT
Nie wiem czy trzeba się logować by przeczytać, więc pozwalam sobie zacytować:
AT - plusy i minusy (wg mojej opinii) względem czarnego:
+ większy zasięg,
+ pełna wodoszczelność (zamiast "zwykłej" wodoodporności),
+ pomarańczowy kolor - krecik będzie trudniejszy do zgubienia - łatwiejszy do odnalezienia,
+ "mocniejsze" światło led,
+ regulacja czułości,
+ możliwość wyłączenia dźwięku,
+ brak fałszywych sygnałów (jeszcze takowych nie miałem), gdy nieco mocniej ciśnie się nim w glebie (czarny często mnie oszukiwał),
+ alarm w przypadku zgubienia,
+ automatyczne wyłączanie,
+ "wyryta" miarka do sprawdzania głębokości wykopu,
+ uchwyt do smyczy,
- wyłączanie przez przytrzymanie przycisku (marnowanie czasu i energii użytkownika) - dla mnie to największa wada tego kreta (strasznie mnie irytuje, gdy chcę go szybko wyłączyć, a niechcący wchodzę w tryb ustawień :evil: ),
- przycisk ze zbyt mało wystającym "brzuszkiem" i słabo wyczuwalny "klik",
- kiepskie rozproszenie światła led - widać "artefakty" diody (w czarnym "krecie" światło jest ładnie - równomiernie rozłożone),
- brak wolnego sygnału dźwiękowego po znalezieniu fanta na granicy zasięgu pinpointera (jaki jest w "czarnym"), po prostu pinpointer od razu zbyt szybko "pipczy",
- cena.
Takie tam:
- nadal kiepska - nijaka ergonomia uchwytu, sprzęcik ucieka z ręki (przydałoby się lepsze wyprofilowanie + chropowata guma),
- nadal brak możliwości wyłączenia światła (krótsze działanie), które i tak jest mało przydatne (większość ludzi kopie za dnia, kiedy nawet w sporym dołku jest wystarczająco widno),
- przydałaby się możliwość używania (choćby jako alternatywa) baterii, czy aku. typu AA (jak ma to miejsce w White'sie TRX).
Podsumowując... Jak nie potrzebujesz wodoszczelności i większego zasięgu, kup czarny, to w zupełności dobry, skuteczny i przyjazny pinpointer.
