DeepTech Vista Gold czy Ktoś używa Opinie
pgpl
Post autor: pgpl »
Witam mam pytanie odnośnie Wykrywacza jak w temacie Vista Gold czy ktoś ma czy ten wykrywacz nadaje się na drobnice kolorową.
Chętnie posłuchałbym opinię użytkowników
Re: DeepTech Vista Gold czy Ktoś używa Opinie
A kto to w Polsce naprawia?
Jak dla mnie zalatuje bułgarską wioską;
Dane techniczne:
Technical Specifications Vista GOLD:
• Operating Frequency..........................................................................25 kHz;
• Detector type.....................................................................................motion;
• Sensitivity control;
• Volume control ;
• Two discrimination modes - silent discrimination and two tone discrimination in ALL metal mode - low tone for ferrous and high tone for non-ferrous metals;
• Quick recovery speed NEW;
• Adjustable recovery speed – slow/fast NEW;
• Volume Adjustable Iron tone (low tone) NEW;
• Booster NEW;
• Searchcoil Type .......................................................................................2D;
• Searchcoil Size.......................................................................................11”;
• Cable Length (approx.).............................................................53” (135 cm);
• Audio Frequency (approx.)..........................................................780/390 Hz;
• Weight (with batteries)........................................................(approx.)1400g.;
• Consumption (without sound, with Booster OFF)...................................43 mA;
• Consumption (without sound, with Booster ON).....................................52 mA;
• Battery Life (typical)...................................................................20-25 hours;
• LED control for Battery;
• Optimal Temperature Range..............................................................10-40 C;
• Optimum Humidity....................................................................0 - 75% R.H.;
Moja opinia jak widać mocno sceptyczna. Czy nie ma innych wykrywaczy - mniej egzotycznych?
pgpl
Post autor: pgpl »
Firma Multi-Moto ma te wykrywacze na youtube są testy i powiem całkiem całkiem sobie to radzi szczególnie z separacją żelazo z kolorem dlatego pytam jak się to sprawuje. Widziałem test gdzie na monecie leży gwóźdź i sygnał dostajemy na metal i kolor gdzie niektóre wykrywacze lepszych firm przy takim teście albo sygnalizują sam złom albo przy włączonej dyskryminacji jest cisza.
Podobno na wyspach ten wykrywacz jest bardzo popularny nikt z nim nie lata ?
Testy handlarzy na youtubie? Bądźmy poważni.
Podobno, słyszałem, kolega powiedział, na youtubie widziałem etc.
Widać u nas sama ciemnota, która z niewiadomych powodów nie rzuciła się na ten cud technologiczny. Może sparzyła się na rewelacyjnych bułgarskich Nexusach czy Blisstoolach - które także miały wymiatać.
Nic tylko propaganda jak w "wiadomościach". Zalecam wzięcie zimnego prysznica - a potem szukania wiarygodnych informacji. Ja ich nie posiadam. Pan na razie też nie.
zdzichu
Post autor: zdzichu »
Na drobnice małą będzie dobrym rozwianiem lepszym niż golden mask 4 jak komuś pasuje analog .
Teraz trochę krytyki :) Te analogi jak i większość podobnych mają swoje wady. kamienie magnetyczne utrapienie, na żwirowisku można dostać hopla i nakopać całą stertę kamieni , bez wyjątku jaki model wykrywacza . trzeba stroić co kawałek w takim terenie .
Visty mają identyfikacje dwu tonową , w porównaniu modele tesoro tylko jeden ton.
Jeśli biegasz po zakoksowanym terenie nakopać sie idzie co niemiara jak to w analogowych wąski zakres identyfikacji .
Osobiście nie preferuje analogowców (tych) z powyższych powodów .
Ja posiadam cyfrowego wysokoczęstotliwościowca nowego G2+ ltd jeśli można porównać do analogowców to jest wolny od takich przypadłości z kosmicznie lepszą separacją
pgpl
Post autor: pgpl »
Jakby ktoś chciał jeszcze zobaczyć test Visty Gold vs Garrett Ace250 to jest link dla nie zdecydowanych na sprzęt tego typu
https://www.youtube.com/watch?v=mwMFWvYHDDk
A co do G2 to owszem może jest lepsza przez to że ma cyfrowy wyświetlacz ale kosztuje o połowę więcej niż Vista :D
2400zł vs 3370zł różnica prawie 1000zł w cenie 2400zł raczej nie znajdzie się lepszy sprzęt a co do kamieni to wydają specyficzny odgłos z echem szybko idzie rozpoznać czy pod cewką jest metal czy kamień
znowu jakieś gówno z youtuba?!
Litości!!
pgpl
Post autor: pgpl »
ProScan pisze:znowu jakieś gówno z youtuba?!
Litości!!
Akurat posiadam ten sprzęt i test zrobiłem sam obiektywnie nie zachwalam sprzętu pokazałem jak działa nic nie kombinowane jak ktoś nie wierzy w test zapraszam w każdej chwili można powtórzyć w terenie
zdzichu
Jeśli chodzi o ten "Nail Board Test " to moneta na pozycji 2 i ruchu 4 jest całkowicie blokowany sygnał detekcji czyli nic nadzwyczajnego , na innych cewkach sytuacja będzie taka sama . Nie wiem jak sprawdzi sie najmniejsza dostępna cewka . Jeśli chodzi o analogi GMP z cewką 9" tego nie przejdzie ale tejon na cewce koncentrycznej tej w pakiecie zrobi to całkiem dobrze .
O innych nie będę pisał.
trochę więcej o tym sposobie testowania bo coraz więcej na różnych forach tak sprawdza.
https://www.ahrps.org/tipsandtechniques.php
kawe
Post autor: kawe »
Posiadam Viste Smart od kwietnia 2014 oraz Viste Gold od marca 2015. Mogę więc (chyba) już coś o tych detektorach powiedzieć. Faktycznie, tak jak piszą, jakość wykonania mogłaby być lepsza, choć ja jak na razie nie miałem problemów z tym związanych. Jak na razie, miałem porównanie do takich maszyn jak ACE 250, CZ-3D, Omega 8000 z cewką DeTech, GM 4, AT PRO.
Visty ---> według mnie <--- :
- Bardzo dobra stabilność, jak dla mnie duży plus.
- Bardzo szybki przetwornik (czy coś tam odpowiedzialne za separacją i odzwierciedlenie dźwięku), na prawdę świetnie na zaśmieconych miejscówkach sobie radzą.
- Duża "czytelność" dźwięków. Możliwe że to przez szybkość z jaką są wytwarzane dźwięki i ich analogiczny ton. Długo nie trzeba się zastanawiać, czy dany sygnał kopać.
- Łatwość obsługi, choć to ma większość analogów...
- Dobrze wyważony, to także nie jest nic niesamowitego
- Co do zasięgów..... uch.... najcięższa sprawa... bo najwięcej tutaj ludzie się kłócą w kwestii tego który wykrywacz jest głębszy... . Ja jestem bardzo zadowolony z zasięgów Vist, co prawda wybrałem je ze względu na separacja + szybkość przetwarzania dźwięków. Jak na razie, najgłębsze dołki kopię z Vistami (GM4 jest równie głęboki). Zasięgów w air testach nie podam, bo to bezsens, tak samo testy w ziemi, rządzą się swoimi prawami - rodzaj gleby, wilgotność gleby, EMI w danym miejscu etc. etc. Jedynie mogę powiedzieć, że zasięgi zgadzają się w moim przypadku z tym (wydaje się że wiarygodnym) filmikiem:
https://www.youtube.com/watch?v=elpZY99 ... dA&index=5
Ogólne wrażenia na duży plus. Faktycznie wracam na stare miejscówki, bądź te szerzej znane w mojej okolicy i czesze je ponownie. Szczególnie te gdzie sporo różnorakiego śmiecia było i jest. Są takie poletka które większość sobie odpuściła a ja nadal, chodząc spokojnie, wyciągam tam sporo dobrego. Nie wiem jak by to było z innymi wykrywaczami, może podobnie, może nie... wiem że poprawiam nie raz, po droższych maszynach. Bardzo szybko się z maszyną zrozumiałem i uważam że czytelność dźwięków jest na najwyższym poziomie. W kwestii takiego subtelnego odczucia odnośnie ilość "łopato-godzin" przypadających na ilość fantów, jak dla mnie bardzo zadowalająco. W kwestii wyciągania cieniutkich sreberek, denarków, szefów itd., jest to jak na razie moja najlepsza maszyna do takich rzeczy (kumpel z GM4 także radzi sobie bardzo dobrze).
uch, jak ktoś będzie chciał więcej opinii, doświadczeń czy rzeczy które są na minus, to dajcie znać. Postaram się możliwie szybko odpowiedzieć.
leszek
Post autor: leszek »
Witam , "kawe" trochę przybliżyłeś Vistę Gold , czy możesz jeszcze napisać coś na temat odporności na zakłócenia elektromagnetyczne . Miewałem z tym częste problemy . Linie energetyczne są od dawna moją zmorą . Biegam z T2 wersja 6.0 czyli nie najnowsza , jednak jest to mój dziewiąty wykrywacz na przestrzeni kilkunastu lat . Miałem w tym kilka naprawdę markowych sprzętów jednak problem pozostał .
taboon
Post autor: taboon »
Vista Gold jest dobrym wykrywaczem, porównywalnym do GM4 WD PRO. Nie jestem handlarzem ale użytkowałem oba, dodatkowo też Vistę Smart +. Twierdzenie, że separacja jest lepsza w G2, czy innym Fisherku, to jakaś pomyłka... miałem też te sprzęty przez kilka lat..nikt mi nie wmówi, że czarne jest białe :-). Wybór Vista jest bardziej toporna, GM4 nie ma regulacji głośności żelaza... Oba lubią w mniejszym lub większym stopniu kamienie magnetyczne, wszystko zależy od cewki. Robiłem testy tych wykrywaczy w terenie, chodzac Gm4 i Vistą po konkretnym kawałku..żaden nie znalazl po poprzedniku niczego wiecej..
Oba są lepsze niż Fishery, Garrety, nawet Deus..miałem i sprzedałem - powód? Gorsza separacja niż GM czy Vista. Nic tego nie zmieni..tak jest i już .....gdyby były lepsze, to bym ich używał...używałem,,,,ale jak się pojawiły te..
taboon
leszek pisze:Witam , "kawe" trochę przybliżyłeś Vistę Gold , czy możesz jeszcze napisać coś na temat odporności na zakłócenia elektromagnetyczne . Miewałem z tym częste problemy . Linie energetyczne są od dawna moją zmorą . Biegam z T2 wersja 6.0 czyli nie najnowsza , jednak jest to mój dziewiąty wykrywacz na przestrzeni kilkunastu lat . Miałem w tym kilka naprawdę markowych sprzętów jednak problem pozostał .
Ja mam GM$ WD PRO i mam to...8 i 18khz.. wystarczy pyknąć i zmienić częstotliwosć i nadal śmigasz nawet pod dużymi liniami
